Clutch and TOB Replacement - Lessons Learned and Info
I did lube everything. Though I didn't replace it due to advice that it was more trouble than it was worth...I hope not to own it long enough to find out I was wrong!
Fantastic information!
I just wanted to comment on how this is a fantastic writeup! Thank you for the info!
I had a similar experience, and this thread and others online definitely made it easier. As I posted on another site, here are some of my notes, just FYI:
- Removing the transfer case prior to removing the transmission helped greatly and made it easier to manage
- I replaced a leaking rear main seal while I had the flywheel off at a machine shop getting refinished...might be something to consider based on the age of your Jeep while you're already in there.
- As many suggested, I replaced the TOB and pilot bearing while I had everything apart.
- It's a great opportunity to use some aluminum tape to repair the heat shielding that sits between the transmission and the main body.
- As someone else mentioned, taking some long bolts and grinding the heads off to use as a guide when reinstalling the transmission makes it much easier to align everything when you put it back together.
- I also took this opportunity to replace the upper and lower oil pan gaskets, since I had everything apart since the upper was leaking (which i've heard is common on some JK models)
- Replaced the slave cylinder as well, along with a rusty hydraulic line from the slave to the master.
I still can't believe how well the clutch feels after replacing everything, and how smooth it shifts. It was a lot of work, but I have a much better understanding of how this part of my Jeep works and I definitely saved myself some cash doing it in my garage.
Best of luck, and thank you again to everyone who posted on here!
Has anyone done this and measure the washers, the numbers below don't work out for me.
The bolt is 9.4mm or .370in so a .6mm ID wont fit ... or am I looking at putting this in the wrong place ?
The OD of the cupped washer is 22.7mm or .89in
I'm assuming I Need a washer similar to these dimensions but want to confirm the 2.25mm x 2 thickness is correct spacing.
