EVO JK Rock Stars
Off Road Evolution supplied pretty good instructions, but I thought I would try and add to them.
Jack up your jeep and support it using jack stands with the back tires off of the ground. Remove the tires, shocks, sway bar links, brake caliper, & lower control arms. Shock mount prior to EVO Rock Stars. http://my.project-jk.com/data/1664/m...ch_lift_11.jpg Measure 1.5 inches down from center of the lower control arm bolt hole. http://my.project-jk.com/data/1664/m...ch_lift_02.jpg We used a sawzall to cut the bracket & shock mounts then used a grinder to trim and smooth things up some. http://my.project-jk.com/data/1664/m...ch_lift_13.jpg http://my.project-jk.com/data/1664/m...ch_lift_19.jpg We then painted the bare metal and test fit the Rock Stars. http://my.project-jk.com/data/1664/m...ch_lift_24.jpg http://my.project-jk.com/data/1664/m...ch_lift_25.jpg We then installed the bolts. Remember the small lower bolt needs to be inserted from inside the bracket so the nut is exposed. The small upper bold is inserted from the outside so the nut is on the inside. http://my.project-jk.com/data/1664/m...ch_lift_26.jpg http://my.project-jk.com/data/1664/m...ch_lift_29.jpg Now it is time to reinstall the lower control arm. Note: If you are using the EVO Rock Stars along with the TeraFlex axle mounted track bar bracket be prepared to go to the store and pick up a longer bolt for the lower control arm mount, as the stock bolt will not be long enough. This is for the driver's side only. Torque the small bolts to 40 ft. lbs. http://my.project-jk.com/data/1664/m...ch_lift_30.jpg http://my.project-jk.com/data/1664/m...ch_lift_32.jpg I decided to use OME long travel shocks with my lift and ran into a small problem. The rear shocks would not mount into the EVO Rock Stars without trimming the mounts a little to prevent the shock tube from rubbing and the holes to line up to get the lower mounting bolt in. http://my.project-jk.com/data/1664/m...ch_lift_37.jpg http://my.project-jk.com/data/1664/m...ch_lift_36.jpg It is now time to reattach the brake caliper, sway bar links, shocks, wheels, and lower your JK to the ground. After lowering you JK torque you lower control arm bolts to 125 ft. lbs. and your shocks to 90 ft. lbs. This is what my finished EVO Rock Stars looked like. http://my.project-jk.com/data/1664/m...ch_lift_38.jpg |
Great write up look's AWESOME :thumbsup:
Very, VERY cool! I am going to do this soon, so it was good to see the process. Interesting about the OME LT's not clearing. That is also good to know since my new ones will be here on Mon!
Have you stretched it out yet? I'm curious about the springs and down travel. Those OME LT's have about 11" of travel, and if the lower mount just moved up 1.5-2" then you are going to have quite a bit more down travel... maybe 2-3" more than with your other shocks. I wonder if the coils will fall out and if we might need a limiting strap? Also, how do you like those shocks? What is the ride difference like? Thanks for posting up! |
You know what...I just realized I made my install a little more difficult by cutting off the stock sway bar end link mounts along with the shock mount...HA!
Check out my write up for some other helpful hints if attempting this mod :thumbsup: https://www.jk-forum.com/forums/show...evo+rock+stars |
Originally Posted by RubiJK
(Post 948147)
Originally Posted by seal20
(Post 948205)
I'm glad
I'm glad that you were the first guennea pig to try these with the OME LT shocks. Now that I know the EVO Rock Stars have to be modified to use the OME LT shocks I am just going to make my own shock skid plates.
Originally Posted by Bluewaterrider
(Post 948285)
Originally Posted by Robar
(Post 948304)
I believe that EVO has weld on skid plates for the back, I just chose the Rock Stars for my use.
(Post 948318)
Yeah I know but the EVO weld on rear skids only protect the control arm and don't protect the shock at all:naw::sad2:
