EVO rear no flare builder corners
I've highlighted the area of concern in the picture. I'm guessing I'd need to cut/shave off quite a bit of this in order to with the Poison Spyder Rock Skins. Is there anything there that cannot be cut back to accommodate them?
Attachment 438681
Attachment 438681
Eventually I plan on it but I don't think their standard ones will match up since this covers the section of body where the flare mounts to and I believe the rocker skins run up along the flare. I believe they are designed to go with the standard EVO corner and not their full corner like these. That said they wouldn't be hard to trim and make fit. I am not sure that they won't fit but just thinking out loud here. I'll have to check out some pics of them.
Thanks for your replies... $399 is way cheaper than even Northridge's website which shows the non-flare going for $599. I'm so in on this... I don't care how much of a hassle it's going to be to get them to work together.
Be sure to post up pics when its done! I'm glad you were able to get them for $399.
They are 3/16" and I am very happy with the fit after hearing other people talk about having issues with that thick of corner armor. There is a gap at the bend in the back which is to be expected. That particular gap I believe was about 1/8". I will be using black silicone along the top and sides which will hide that gap. Looking down the sides you can see the armor curve to contour with the body, I credit that to using so many clamps when I drilled the holes. I paid $399 from Northridge 4x4.
