Freedom top insulation for about $10.00
HOME DEPOT HAS CONSTRUCTION INSULATION IN 2X4' SHEETS FOR $2.56 I GOT TWO
TOOK OFF THE FREEDOM TOP FRONT PANELS AND CUT THE STYROFOAM TO FIT WHITE SIDE UP
CUT VELCRO STRIPS INTO SMALL SQUARES AND ATTACHED THEM TO THE BLUE SIDE OF THE INSULATION
PULL THE PANEL OUT IF YOU WANT TO PAINT I USED DUPLICOLOR BEDLINER
RE-INSTALL BLACK SIDE DOWN REPLACE TOP
I AM NOT THE BEST GUY ON FINISHED WORK AND I MADE A COULE OF BOOBOOS, BUT I CAN LIVE WITH 'EM. I MAY DECIDE TO PUT SPEAKER CARPET OVER THE FOAM AT SOME POINT FOR A MORE FINISHED LOOK.
My interior usually cools off when i gwet to where i am going because the damn top lets in so much heat. I figure if this stuff works for houses and hotels it should work for this purpose
Looks good, and I'm sure the insulation value is worth it...
...but, I'm curious about the velcor's sticky side holding to the freedom panel!?!?
Keep us updated...
Keep us updated...
