Grill mod with CAD and 3d printer
5 Attachment(s)
yep another grill mod thread...This one was done using 3d cad and a 3d printer. I wanted to come up with a solution that would allow me to use screws instead of the sticky clips and zip ties. I wanted to make sure that the gutter guard was flat to the inside of the grill as possible.
i started by modeling the cross section of the grill and then modeling a block that could be glued into place. Attachment 450226 Then i printed around 48 of the blocks using a Fused Deposition Modeling (dimesion) machine. Once i had the blocks I used tape to align the locations then i started glueing them in using a 2 part epoxy. Attachment 450227 Attachment 450228\ Attachment 450229 I ended up cutting the blocks in half for the location on the top of the grill holes since there was a hose that was in the way. Once i had the blocks glued down, i used the gutter guard stuff that i purchases from lowes. I primed and painted them with some flat black crylon paint. Then i used some wood screws and some finishing washers to hold them on location. Attachment 450230 I ended up using some of the stick down zip tie things along the bottom of the openings just to make sure they didnt flex out on the bottom. |
The results
2 Attachment(s)
It took more time than I have read that it took others but I am happy with the results.
Attachment 450231 Attachment 450232 |
Looks good! Really clean, I like the block idea. Way better than the blocks and zip ties I used.
Sent from my iPhone using JK-Forum |
wanna send me the printer design file ?
I can send out creo-2 files, step, iges, stl... pm me if'n you want a copy
looks pretty good!
