Originally Posted by tommyluv78
(Post 1056829)
thank you so much HG for posting this on here. ever since i got my unlimited i've been looking at the hoists in quadratech and JCW wondering how to build one cheaper. then i saw your creation and to top that off you had the shelf idea. FREAKIN GREAT! i finished mine friday night around 10 or so, couldn't wait to get up saturday morning and take the top off bymyself. well after a little tweaking to find the balance i needed, all is good. thanks again for making things a little easier around here.
For those that are not using a platform, how stable is the top when it is hanging there from wind. I have a garage problem, I don't have one, I have a carport. I have got to have a way to pull this thing off by myself. I need something to be able to pull in, pull off, drive off, then repeat, later that day. I will be taking the top off on weekends only, then putting back on for the week, due to job and security reasons.
I've been looking at the one at a 4 wheel part store. |
Originally Posted by db99wj
(Post 1058047)
I've been looking at the one at a 4 wheel part store. I am moving my hoist out of the garage (A frame on wheels), and then lowering it onto a platform on wheels to roll it back into a shed. Maybe something like that would work for you. But if you want to hang it by the hoist, I steadied mine with 2 bungie cords so that it wouldnt twist while I was backing up to it. Something like that could work for you if you need to keep it up and out of the way, but really the platform doesn't hang much lower than the top itself. I use 2 pieces of wood (1X4) hanging from chains. I was thinking of replacing the chains with straps so that I can crank them higher once the top is on it, since the hoist hangs down 6 inches because of the pulley etc. I gave up on figuring out how I could do this when I decided to go with the lift though since I wont have the height I need in the garage. cheers |
Originally Posted by YellowToy
(Post 1056838)
The eye bolt I used was shorter than 3 inches. The important part is the 1/2 inch, not the 3 inches.
When you say the important part is the 1/2 inch, which measurement is that? |
Distance to back wall of garage? Trying to save space!
I'm planning to build my hoist over the next few weeks. I'm planning on using the U-Bolts to hold up the left/right sides, but will use webbing to support the front/rear. In order to save as much space as possible, I plan to store the hardtop with the rear window down and mount it as close as possible to the back wall of my garage. My question is: assuming the rear window is down, how close can I mount the hoist assembly/hardtop to the rear wall of the garage? I was planning on backing the Jeep up until the spare tire is almost touching the back wall, then mount the hoist directly above that. Any other ideas for saving space?
Originally Posted by uofawildcats
(Post 1058522)
Which dimension is which on an eye bolt? In other words, which dimension does the 1/2" refer to and which dimension does the 3" refer to? I've had different people tell me different things. When measuring the length, I've had some people tell me you measure from below the eye to the end of the bolt while I have had others tell me you measure from the top of the eye all the way through the length of the bolt.
When you say the important part is the 1/2 inch, which measurement is that? The 3" measurement is shown below for an eye bolt. http://www.boltdepot.com/Images/char...olt-forged.gif |
Originally Posted by CSJK
(Post 1058616)
Originally Posted by HG97TJ
(Post 1058618)
The 1/2" measurement indicates the thickness (or diameter) of the threaded end and should match the hole size of the nut.
(Post 1059207)
Then it would seem to me that since a channel is only about 1 1/2" deep, the ideal eye bolt would be 1/2" x 1 1/2". That way nothing protrudes out the other side, no need to cut off any excess, or double up on washers under the eye.
the eye bolt I used had about 1" of thread.
If you are going to try to put the top closer to the wall you have to have enough headspace to raise the closed rear glass above the brake light. I didn't, so I built the rails. After I built it I found out you can buy rollers to use the super strut as a trolley rail. That may have been a bit cheaper. |
