Help setting toe in
Old Feb 17, 2013 | 08:13 PM
k0260's Avatar
Default Help setting toe in
I've read the project-jk write up on front end alignement. Only thing I'm not totally clear on, says to set you toe in 1/16" no more than 1/8". Does this mean basically making the front of the wheels 1/16"-1/8" narrower than the back of the wheels? Just double checking. thanks
Old Feb 17, 2013 | 08:35 PM
filthy-Beast's Avatar
yes that is what you want.
Old Feb 17, 2013 | 08:40 PM
k0260's Avatar
right on thank you
Old Feb 24, 2013 | 09:42 AM
sm_rubi's Avatar
It's a good recommendation that is hard to achieve with some of the after market tie rods like the Rock Krawler because you have the take one side out rotate the TR end link and you never get close enough. However, the oem and "on car adjustment" TR's out there are good for hitting the recommended toe settings.
