JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   JK Write-Ups (https://www.jk-forum.com/forums/jk-write-ups-39/)
-   -   Homemade tow points in the front (https://www.jk-forum.com/forums/jk-write-ups-39/homemade-tow-points-front-173977/)
Frozenman Apr 17, 2011 09:28 AM
I spanned 1/2" x 4" x 37" plate bolted to the frame rails welded 3/4" x 2-1/2 pieces to the front of the plate, cut holes in the stock bumper, trimmed out the holes and produced something that probably won't break
Was a good weekend job in the garage
http://i557.photobucket.com/albums/s...g?t=1303057750
http://i557.photobucket.com/albums/s...g?t=1303165747
Frozenman Apr 17, 2011 05:46 PM
Originally Posted by muddevil (Post 2236057)
Will this work with factory fog lights?
no the tow points are right where the factory fogs would mount up. however, if you have a factory bumper with fog light cutouts in it the tow points would fit where the cutouts are
T&ERun Apr 17, 2011 06:01 PM
Great idea and they look great.
RedOffRoad Apr 17, 2011 07:24 PM
I made a post inquiring about something just like this!!! beautiful. any parts list? or how to on this? I want to do this exactly but was thinking about doing them where the bumper has the bump outs below the factory tow hooks as I have factory fogs.
Frozenman Apr 18, 2011 03:05 PM
I just added a picture at the top that shows how the structure is assembled.
The backer piece is 37" x 4" x 1/2" plate with a 20" x 1-1/2"x 1/2" stiffener welded to the backside of the 4" plate. The hitch lugs that come toward the front of the bumper that are welded on the backer plate are 2-1/2 x 3/4 x 5" long with 1-1/4 holes drilled thru.
I matched the 4hole pattern from each frame rail and drilled the backer plate the same. I drilled the holes bigger than I needed to so I could have some adjustment for good alignment . Hope that helps a little.
As far as putting tow points on the bump outs, I thought of the same but I steered away from that idea because of how far away from the frame rails the fabrication would end up. I was afraid that the torque applied during use of this type of setup would be a little spongy sticking out that far. Also how I made mine is pulling on both frame rails at the same time and ties them together as well.
If you wanted to relocate your fogs and assemble like what I have you could run the tow points thru the fog cutouts and fill the voids with some sort of rubber type foam material, just a thought.
hdtrader Apr 19, 2011 12:23 AM
...you did an excellent job. I like it.
AlgoDan Apr 19, 2011 02:26 AM
Nice and clean mod good job.....:beer::beer:
JkHauler Apr 20, 2011 09:23 AM
I'm not a welder or a really big fabricator but i need to get this done!! Looks great and solid and honestly looks like it was factory work! :thumbsup:
SureShotXd May 7, 2011 08:53 PM
Looks great! I need this done also!
Frozenman May 8, 2011 05:48 AM
Here's a pic with shackles on
Looks like I have a good amount of compliments ( thanks a bunch )
I was thinking of making up few extras for the for sale section, I'll post up if I do.
http://i557.photobucket.com/albums/s...g?t=1304861948
© 2026 MH Sub I, LLC dba Internet Brands
