How to test abs sensor ?
a code reader will tell u which one , other than that disconnect each lead with wheels off ground and spin tire ( for fronts ) set volt ohm meter to ac . should read .2 volt ac if its good . back tires would be harder to spin . also may not necessarily be a sensor although likely . you could also go to advance auto parts and they will reAd codes for free ( easier option )
