My $50 door storage rack
If something similar to this has already been posted, sorry for the repeat. I already had some 2x4 laying around, so I went to the Depot and bought the following:
4 - 2" swivel casters 6 - .5" x 36" steel pipe 3 - .5" x 18" steel pipe 6 - .5" steel elbows 6 - .5" steel floor flange http://www.jasonbrownlee.com/images/...%20001.jpg http://www.jasonbrownlee.com/images/...rack%20002.jpg I made a roughly 2' square with the 2x4 and put a caster on each corner... http://www.jasonbrownlee.com/images/...rack%20003.jpg Then, using all the steel pipe, elbows and flanges, I made 3 vertical stands and attached them to the 2x4... http://www.jasonbrownlee.com/images/...rack%20005.jpg http://www.jasonbrownlee.com/images/...rack%20006.jpg http://www.jasonbrownlee.com/images/...rack%20007.jpg Then, added some pipe insulation... http://www.jasonbrownlee.com/images/...rack%20008.jpg Then, add doors... http://www.jasonbrownlee.com/images/...rack%20012.jpg http://www.jasonbrownlee.com/images/...rack%20009.jpg I'll probably add some padding to the 2x4, but for now it gets the job done. Edit: I have since replaced my original 2x4 base with a furniture dolly to allow for some more room between the uprights. So, it's now my $70 door storage rack: http://www.jasonbrownlee.com/images/...rack%20013.jpg |
Nice job, looks good. If you have an old piece of carpet lying around you could just wrap that around the 2x4 and tack it on underneath.
I guess it'll cost us 4 door guys $100, maybe 2 like that or 1 long one. |
Originally Posted by BJeepJK
(Post 96747)
I guess it'll cost us 4 door guys $100, maybe 2 like that or 1 long one. Probably better to make two like that. Add it that one suggestion of using a furniture dolly for the hard top and I think I may be in business... ...now I just hope I have the right sized tarps... This Jeep-thing is a hoot! |
Looks good CincyJK!
You got my wheels turnin'! |
Very impressive :yup:
After looking at the rather expensive ones in the Quadratec catalog, I had been tossing around this same idea ... wood base with pipes for a nice stable cart and either swim noodles or pipe insulation for padding (2 of them for my 4 dr). Thanks for writing this up ... definitely the way I'm going to go.
Nice work!
I was thinking about making something similar out of 1 1/4" thick walled (high pressure) PVC instead. Do you think that will be strong enough, and very light, and non scratching?
Thanks CincyJk, I will make two of those for mine, while I wait another month for delivery.
Thanks for sharing your great idea! It's so simple, even a caveman (I) can buid it!
