My Full DVD Monitor Write up part 1
Old Feb 27, 2007 | 07:17 PM
RedRocRubi's Avatar
It's for my wife to watch while were driving. I hate talking.
Old Feb 28, 2007 | 08:35 AM
mikesjeep's Avatar
Default install video for me
Hi DBB888,
I live in So Calif, Seal Beach.
How much will you charge to install that unit in my 07 Rubicon?
I guess I would have to fly you here if you don't live in So Calif?
Thanks
Mike
Old Feb 28, 2007 | 08:41 AM
RubiconToad's Avatar
Great write up,
if I understand this correctly, you have the factory 6-Disc head unit? You mention Sirius but is that just a mount you had? So this will work if you have the 6-Disc CD/DVD?
Old Feb 28, 2007 | 09:32 AM
DBB888's Avatar
Hi Guys
Yeah I'm in NJ- wouldn't know what to charge-
Yes Its the factory head unit with dvd and sirius and 6 disc. If it says DVD on the bottom left corner your good to go. The mount was from a kit I bought for my other car.
Mike
Old Feb 28, 2007 | 09:49 AM
mikesjeep's Avatar
Default drive to Jersey
I guess I'll have to drive my Rubicon to Jersey to have you install the unit?
Another question: are you able to play the DVD and also listen to the radio at the same time.
In other words, can the rear passengers watch the DVD with head phone and the driver listen to sirius or radio?
Thanks
Mike in Seal Beach, CA
Old Feb 28, 2007 | 10:50 AM
DBB888's Avatar
If you make the trip- I'll do it for free
The head unit can only do one at a time- Just DVD or Just radio- you can load 6 DVD's !!
Old Feb 28, 2007 | 12:13 PM
mikesjeep's Avatar
Default mygig vs 6cd player
Hi Mike,
I actually heve the mygig on order, course it hasn't come in yet.
According to other threads and info, the mygig has a video out to a video screen which you can play both the radio and the DVD at the same time.
I guess I'll find out when it comes in.
My second choice would be to go with the mygig or 6 CD player and buy a seperate DVD player/monitor for the rear passengers.
Thanks again
Mike in Seal Beach
Old Feb 28, 2007 | 12:45 PM
kaffeene's Avatar
Question
Hey I'm in Jersey!
I'm still trying to figure out what audio configuration I would want when I get a JK. I've got plenty of time though, but it's fun to think about.
DBB888... you were an audio installer, right? How is the stock setup?
Not sure if I should bother with the factory stereo (CD, 6 disc DVD or MyGig) or go aftermarket.
I know that I want to add a small sub & probably a 4ch amp for the speakers.
I'm not sure if it's going to make a big difference with having rca pre amp outputs off of an aftermarket stereo or using the factory stereo and using speaker level inputs on the amp(s) or a line output converter.
What do you think...pre amp outputs, speaker level inputs or line output converter?
Rockford Fosgate has a device out that basically seems like an enhanced line output converter that has an eqalization curve, which might work well for the factory equalization settings that supposedly fade the rear soundbar speakers out.
http://www.crutchfield.com/S-yJR7jLD...5753SIXTY1#Tab
Is there a way to adjust the factory equalizer settings?
Did you upgrade the factory speakers or do you plan to?
Thanks for any info
Old Feb 28, 2007 | 02:53 PM
DBB888's Avatar
I learned to like it so far-
If I was to go aftermarket, there is no question that I would use Pre Amp outputs. Amps are the way to go. A 4 channel and sub amp and your rock-in or Booming.
Only if your really set on a factory look would I use the rest.
For now Im content with having a set up that is already paid for and getting the most out of it. Talk to me in a few months when summers around and see if I put a lot ofmy left over audio stuff in though. I have Sirius for free for one year though. Maybe after that I’ll change it.
>Rockford Fosgate has a device out that basically seems like an enhanced line output converter that has >an eqalization curve, which might work well for the factory equalization settings that supposedly fade the >rear soundbar speakers out.
Hmm- never heard of anyone trying this- It’s a thought though. I’m going to keep this in mind.
Nope
Plan to – Definitely
I’m in Edison NJ so if your close and then next time I do a project, I’ll let you know.
I put and airhorn in today because I can’t stand the factory one. Only downside is, I lose the factory arm honk because the airhorn needs a second to pulse the relay and by that time its to late
Old Mar 2, 2007 | 06:52 PM
hotdogging's Avatar
I think I found the perfect ideal solution, I saw this a few weeks ago...haha
http://www.jakeludington.com/xbox/20...e_driving.html
