Plasti Dip testing
Old Mar 18, 2013 | 04:46 AM
  #261
Gforce!'s Avatar
From: Independence and Lexington, KY (depends on the time of year)
Originally Posted by jeepchief
I did all this sometime in October/November, Just noticed I never posted on this thread.
the girlfriend did the interior pieces on her Nitro
I did the R/T stripes, wheels and badges on her Nitro
Did the chrome grill slots and side (fake) vents
the fun part....
Blaze Blue
Plasti-Dip Smoke
Grill and Hood
Did my mom's tracker for a bday present
BEFORE....
AFTER...
BEFORE...
AFTER.
Looks brand new..haha
I will be doing a lot more when the weather gets nicer!!
How's it holding up on the muffler? I was considering doing mine, but I thought the heat would make it come off
Old Mar 18, 2013 | 07:08 AM
  #262
justanothermoparman's Avatar
I don't think he did the muffler, he did the diff cover and the shocks though.
Old Mar 18, 2013 | 03:09 PM
  #263
jeepchief's Avatar
Correct...I didn't do the muffler. I painted that a while back w/ reg spray paint and the heat burnt it off. I will be doing the muffler with a high-temp paint. PlastiDip is supposed to hold up to 318 degrees I believe. Not sure how hot a muffler gets but I know it can't be hotter than an engine gets. I might test it out this spring/summer
negative on the write-up. I just eyeballed it as I taped off. I didn't measure anything, it was a quick job. If it was permanent I would've been more particular about it.
Old Mar 24, 2013 | 04:50 PM
  #264
John410's Avatar
Originally Posted by Jstwhln
"Plasti dip testing" is a good name for this thread! I tested red for the vent bezels, cause my highlight color on my jeep is going to be red, but I changed my mind it was too much. So I went with color matched bezels. I like this better.
How'd you get those vents out, I was thinking about doing mine but I can't figure how to get them off.
Old Mar 24, 2013 | 05:10 PM
  #265
RavenZ33's Avatar
If you look on the inside of the vents you will see a notched out section, line that up at roughly the 1 o clock position and use a small screwdriver to stick in the small hole. Once pushed in just turn the entire vent ring counter clockwise, remove screwdriver and the vent will come out. Good luck
Old Mar 27, 2013 | 11:18 AM
  #266
Jeepinxj's Avatar
Default plasti dopped hinge question
Question for those who plasti dipped your hinges. Is there anything special you need to do at the pivot points of the hinge. Do I need to cut the plasti dip with a razor before opening the doors?
Old Mar 27, 2013 | 11:41 AM
  #267
BigDaddy's Avatar
I opened and closed the doors while the PD was still wet. I wasn't sure if it would work but I haven't had any issues
Old Mar 30, 2013 | 10:44 AM
  #268
lvd76's Avatar
Finally warm enough in NJ to dip my wheels!!
ID:	440316   Click image for larger version
Old Mar 30, 2013 | 10:53 AM
  #269
SRJeep's Avatar
I really like the change
Old Mar 30, 2013 | 02:15 PM
  #270
lvd76's Avatar
A few more pics from my black out project...
ID:	440411   Click image for larger version
ID:	440412   Click image for larger version
