PSC Power Steering cooler kit
Old May 1, 2012 | 12:49 PM
Quentin_T's Avatar
Default PSC Power Steering cooler kit
Here's a quick write-up, I was a bit nervous to do this without directions, and just kinda went with it. It didn't turn out to be hard at all, just over thought the process.
Tools used: Flat head, philips, 7/16 socket and wrench, utility knife, a pair of dikes, and a drill with 3/8 bit for self tapping screws.
Optional (only for some, not me) BEER!
Step 1 was to remove the air box and get it out of the way completely.
Step 2 was to drain the reservoir, just dumped it into 1/2 a gallon jug cut open.
Setp 3 was simple, mounted the bracket in the front (after removing grille) with 5 self taping screws.
Step 4 remove the line from side of reservoir
Step 5 splice into return line seen here
Step 6 connect new line to reservoir
Step 7 I cut a hole in this plastic next to radiator to run from return line to cooler
Step 8 mount cooler and cut new lines to fit properly
Step 9 Refill reservoir, and start the jeep. Fill as needed while cycling steering 10-12 times.
All buttoned up.
Old May 1, 2012 | 03:58 PM
JKJA10's Avatar
great post, how is it working?
Old May 1, 2012 | 08:08 PM
sm_rubi's Avatar
Nice write up dude! I'm sure it'll help out a fellow member!
Old May 2, 2012 | 08:14 AM
Quentin_T's Avatar
Thought I would finally contribute something. Well, after letting it sit idling, there was some heat through it so it appears to be doing it's job, with no leaks.
I already blew a pump, so this is why I decided to do this, even though changing the pump was really easy, it's not something I want to do on the trail.
Oh and I took it out this weekend with no leaks or funny noises, and no blown pump!
Old May 16, 2012 | 07:29 PM
William's Avatar
Nice writeup. I'm on my second PSC pump and it still make more noise then I think is right. Have you had any trouble?
Old Aug 14, 2012 | 03:43 PM
JeepBerg's Avatar
Thanks for the write-up. I plan on doing this soon. Can you explain a little better (maybe a diagram) which hoses go where? Thanks.
