Raingler Divider Net
Hope this is the right area to post this. Has anyone installed the Raingler divider net behind the front seats on a 2 door yet? Their website says it installs behind the rear seat. I remove the rear seat when we take our Rotty for rides and would like a divider net to keep him from coming up front and to also be strong enough to stop his forward movement in case of hard braking. I have a harness for him but havent come up with a way to secure it yet. Attaching it to the floor is out of the question because it gets tangled around his legs. (He goes from front to back to side to side, around and around checking out the scenery!)
So far doing a search here I found the following. I know it is not exactly what you wanted but there is some good info in them. I hope this helps.
https://www.jk-forum.com/forums/show...light=raingler
Got ya. Most people asking questions have not tried doing a search yet. I am not sure if anyone has done what you have in mind. It might require a little bravery and modifications on your part. The JK has not been out long enough yet for folks to have tried everything. Her is something that goes with the above info though that I just learned that might make it easier for you to come up with your own way to rig it. As I said I hope this helps some. Myself I am looking for cheap cargo netting so I can make my own because I don't want to spend the money and I want something custom.
https://www.jk-forum.com/forums/jk-write-ups-39/rear-cargo-tiedown-anchors-3809/
Thanks, let me know if you find some netting. I would be intrested also but it would have to be strong enough to stop a 110 lb Rottweiler from coming up front. I did find some netting but it was around $18 per square ft!! Paying for a lot of "air" there!
