Rigid back up lights
Old Feb 9, 2013 | 07:18 PM
Gilbemods's Avatar
Default Rigid back up lights
Here's a quick write up on how I did this mod. I will be updating it between today and tomorrow with part numbers and more details.
I started by removing the light, for Philips screws and it just pops out. Make sure you unplug the light harness in the back
Old Feb 9, 2013 | 07:20 PM
Gilbemods's Avatar
I placed the bracket on the light and marked the holes with a white china marker. Becareful when drilling not to go too deep. There's a space between the light and housing.
Old Feb 9, 2013 | 07:22 PM
Gilbemods's Avatar
After I drilled my holes I mounted the bracket to the housing and the led light to the bracket
ID:	420291   Click image for larger version
Old Feb 9, 2013 | 07:24 PM
Gilbemods's Avatar
I made a notch in the plastic for the wires, you can use a large drill bit or a round rasp.
Old Feb 9, 2013 | 07:26 PM
Gilbemods's Avatar
After I wires everything, reinstalled the brake lights and enjoyed!
ID:	420295   Click image for larger version
Old Feb 9, 2013 | 07:28 PM
Gilbemods's Avatar
Here are some action pix
ID:	420297   Click image for larger version
ID:	420298   Click image for larger version
Old Feb 9, 2013 | 08:40 PM
lowendrider's Avatar
Very nice. How about some details on the wiring for us with limited wiring skills. Also, did the bracket come with the light?
Old Feb 9, 2013 | 11:04 PM
troyboy's Avatar
Nicely done man. If I had to do it over again I wouldn't have put mine into the bumper. Your setup is way better.
Old Feb 9, 2013 | 11:06 PM
troyboy's Avatar
What lights are those?
Edit: doh, never mind. It's really late.
Old Feb 10, 2013 | 04:25 AM
Gilbemods's Avatar
Thanks man! There's no reason you can't still do this setup
