Rubi rail conversion
Originally Posted by Scoak
Does anyone have a write up for converting JKU Rubi rails to a Jk?
To lazy to look...
To lazy to look...
There is no reason for a write up. The mounting points are the exact same, so all you have to do is cut to length and pull cap off cut off piece and put back on end cap of existing rail. We've done tons here, and it's that simple
Not sure for cutting down for a 2dr would image the mounting is the same. I have cut mine down twice for clearance. Easy to do; remove caps, mark cut lines around rail, cut with grinder or reciprocating saw (be sure not to overheat or paint will bubble), drill hole for new cap plug (3/8" bit), masking tape off exposed steel, paint, re-install caps, bolt to jeep THEN
