Rubicon Locker By-pass --- Off Road Engineering's kit
#21
#22
Ooooooh, I'm no electrician so I'm not sure. But, it would seem that if you did what I did (except run the wire from the relay to your own switch/plate) that it would work exactly the same. But I'm not sure, and at the cost of those switches I would be making damn sure it will work before I just started cutting into some wires. Also, you should probably add some type of main shut off switch somewhere too so it doesn't accidentally get turned on.
#23
I agree on the safety switch idea. From the diagram in above post it looks like you take the pos & neg wires from the cig lighter and one wire from the relays. My question is does the locker button supply the relay with 12volts or ground? It depends on how the switch is wired
#24
#25
Call SPoD and speak with John Angelastro. I still need to get an SPoD for my JK. I had one on my TJ, and did a locker bypass mod using the SPoD. John helped me figure out how to do it.
#27
My '08 doesn't lock in 4 hi. It's not a matter of when they changed it. It's supposed to lock only in 4lo from the beginning.
Put it in 4hi, then jack up the axle you want to lock. Lock it and spin a tire by hand. See what happens.
#28
#29
Switching between rear or front and rear is a factory option. But lockers were never available in 4 hi. Like you stated before, the previous owner must have done something. You dont have any buttons to press... they just simply work in 4 hi?
