Side marker light mod diagram
ok, so I did a search for "side marke light mod" and got a ton of hits, what I am looking for is a wiring diagram showing the connections needed to enable the side marker light to work with the turn signals, found plenty of pictures, but being very simplistic, I was hoping for a simple diagram.
Thanks.
Thanks.
Thanks.
Thanks.
danielsternlighting.com/tech/markerflash/markerflash.html
I was very hesitant about doing this as well at first. The first time I was going to do the mod I actually stopped because I didn't have a diagram, but I reread everything, and took my time tracing the wires. It really is easy to do. I completely understand your hesitation to do it, I don't like screwing with electrical too much.
The one thing that I did, is after I did the tap splice, I filled the splice with some dielectric gel to help keep water away from the connection.
I would say good luck, but I don't think you will need it. Just take your time, it is easy.
