So I attemtped to...
Old Jun 14, 2011 | 06:54 AM
msalvas's Avatar
Default So I attemtped to...
Bedline my stock Infinity sub enclosure yesterday. I felt like I had done a pretty good job prepping the surface and all, but after two pretty decent coats of Dupli-Color bed armor the shit peeled off after it dried and pooled up in certain areas and then I was right back to square one. Not really sure what I did wrong but if anyone can offer some advice it would be greatly appreciated. Thanks
Old Jun 14, 2011 | 06:57 AM
Davep22's Avatar
Are you bed lining the plastic directly or is it primed? How did you prep it?
I have little experience with the Duplicolor brand, and I have noticed a bit of peeling with it as well (on a metal surface).
I've used Rustoleum in the past with no complaints.
Old Jun 14, 2011 | 07:46 AM
msalvas's Avatar
Yeah I bedlined the plastic directly, but sanded the surface before I sprayed. I was so pissed when I looked at the pool of bed armor and while trying to fix the pool I noticed it all peeled right off.
Old Jun 14, 2011 | 07:53 AM
Noxian's Avatar
You are going to want to use a plastic primer, you also want to wash the plastic with soap to remove any oils, sanding is also a good idea, then you want to make sure your primer is compatible with the bed liner.
Old Jun 14, 2011 | 08:02 AM
Davep22's Avatar
As Nox said... reprep the sub (peel off the defective liner, sand a bit, wash it up and prime it). The duplicolor should stick, I know a lot of people have used it on multiple applications, but from what I've seen it goes on a bit thicker than other brands and can pool a bit more.... take your time on the coats and give it a bit of distance as you do them.
Check the can of the duplicolor BL and see what it advises for applications, it is a bed liner for trucks (painted metal) so it may not want to naturally stick to plastic. It should stick to a coat of primer. And a plastic primer should stick to your sub.
Good luck - post some photos of the finished product!
Old Jun 14, 2011 | 08:11 AM
msalvas's Avatar
I'm glad you guys are around or I would be lost lol. I'll have to give it a go next weekend since im back to work tomorrow and getting married the weekend of the 25th. Thanks. for the help guys!
Matt
