Spidertrax Wheel Spacers Installation Write-Up
Old Jul 16, 2009 | 09:41 AM
wayoflife's Avatar
JK-Forum Founder
Thumbs up Spidertrax Wheel Spacers Installation Write-Up
If you want to run bigger and wider tires on your Jeep JK Wrangler, you really need to do one of two things. One, buy a set of new wheels with less back spacing or two, install a set of high quality wheel spacers which will effectively reduce the 6.25" of back spacing that your factory wheels have. Of course, if you are someone who really likes the look of factory wheels and would prefer to keep them or, if you’re on a budget and are trying to build up your JK as economically as possible, installing a set of Spidertrax wheel spacers is the answer for you.
Made out of 6061 T6 and anodized blue aluminum for corrosion resistance, Spidertrax wheel spacers are designed to be wheel and hub centric and come with pre-installed wheel studs, lugnuts and Red Loctite. Basically, everything you need for proper installation. And, the best part is, they are very affordable and very easy to install.
Old Jul 16, 2009 | 09:47 AM
jason0341's Avatar
Too bad these are out of stock everywhere right now
Old Jul 16, 2009 | 10:05 AM
Northridge4x4's Avatar
Sponsoring Vendor
We have a hundred in stock ready to ship.
David
Old Jul 16, 2009 | 10:37 AM
atuldo's Avatar
trying to get original lugnut(spidertrax),1x piece,who sells them? did try usual autoparts-not even close to be the same...
Old Jul 16, 2009 | 10:53 AM
FJAggie07's Avatar
David
Wow, great to hear, thanks!
Old Jul 16, 2009 | 02:21 PM
Sponsoring Vendor
we have those in stock also
David
Old Jul 16, 2009 | 05:22 PM
keneds's Avatar
David
Any sales upcoming in the near future? I have the itch....
Old Jul 22, 2009 | 11:17 AM
Sponsoring Vendor
Not on the spacers by themselves but if you order a lift kit at the same time we can do something for you !
Still have plenty in stock.
David
Old Jul 22, 2009 | 11:25 AM
opdsgt's Avatar
Spidertrax calls for 85-90 ft-lbs torque. I chose to torque to 95 (because the owner of the company says he typically takes them to 100 pounds on the initial install).
Then when you go to recheck torque, set your torque wrench to 90 pounds rather than 95. If you don't budge the lug nuts you're good to go; if you do move one or more, you need to reinstall the spacer as if from the beginning (as you will have broken the Locktite).
This is consistent with what the owner of the company has actually stated elsewhere on the forum...
Old Jul 31, 2009 | 02:48 PM
Sponsoring Vendor
We got you covered on spacers, we have plenty in stock ready to ship
Thanks
David
