Storage box
Here are the pictures and how i did the storage box for the back of my Ruby jeep.
Baught box from oly4x4.com for 250.00 + tax. The box is 30x36x14. Got it home and removed back seat and stored it, then put box in back and took measurments for slots in bottom and up side. Used a right angle grinder with metal blade and cut the slots then test fitted and adjusted slots then cleaned edges. After putting box in place and found that the plastic shims under the back seat front hoops worked perfectly, used 3 per side and hammered them in then packed it full of stuff.
Here are pictures.
I applogize if this in the wrong area,
Kat
Here are pictures.
Kat
I like the zip ties too. Can't ever have enough zip ties, 100mph tape (aka duct tape), 550 cord, and extra wire with you.
and don't forget the BFH I'm sure there is one in the tool box there. You also get
for the E-Tool.
Yes have nascar duct take for those yotas that need to be put back together. and 2 bfh's 1 dead blow and 1 3 lb steel one. The air compressor has been moved out and pemimently mounted on the outside. Added hot dog cookers, spare sweatshirt, spare winch relay, D44 rubicon u-joints, u-joint press and a couple of other things.
Thanks Lots for your encuragements.
