Terflex mudflaps mini Write-Up (alternate)
Old Apr 27, 2010 | 09:09 AM
krech's Avatar
Default Terflex mudflaps mini Write-Up (alternate)
this is an alternate to Way of Life's writeup, similar but not quite the same. short and simple since I didn't take enough pictures.
first mounted the bracket using the same holes that were previously used and had to grind the top hole to make it fit using the existing two bolts
then inserted the bar and mesured to the end of my bumper, then cut the bar.
I wanted the mudflaps to be pretty even with my bumper (EX-1) and fender flare so I made my own holes in the mudlap and didn't use the fourth so the flap could slide over the bracket. hopefully they aren't that picky since my tires stick out just a little bit.
drilled a new hole for the pin.
finished (still going to bed line the metal peices)
