Timing chain replacement
This may be in my near future, 90K on 08 JK. Do you have a list of everything you replaced? I have put 2 water pumps in mine so far due to leaking... thinking next one will have to be a Mopar OEM rather than rebuilt/manufactured. What timing chain sprocket do you recommend? Very nice write up by the way!
Timing chain kit: MOPAR 68001402AA (Standard Replacement)
Crankshaft seal: TIMKEN 3638
Oilpan gasket: FEL-PRO OS30622R
Waterpump: MOPAR 4666044BB
Mopar sells a gasket kit for the chain replacement process that has everything you need. Probably can get it from Rock Auto as well. It is part #68029544AC.
Because the factory chain wore out so quickly I was tempted to try a Melling kit but couldn't find out anything about it. Might be worse, who knows.
Good luck!
Good luck!
Thanks to this I was successfully able to replace a friend's timing cover gasket. No more leaks!
A few tips I have
- Blow out all the holes behind the timing cover to get all the dirt, oil, and coolant out. I had to buy a new TC gasket because when I put everything back together the first time, a bunch of oil came out of one of the holes and got all over the gasket before I could tighten everything down.
- Not required but my 15mm TC bolts were really crusty so I cleaned them on a wire wheel and put some thread sealant on them.
- Remember you're removing the UPPER oil pan. I was in a rush and didn't notice that you were supposed to remove the upper oil pan (the frame) and leave the lower pan attached. I ended up cracking the upper part trying to pry the TC off and having to weld it back.(+2 days)
- The service manual says not to use any type of sealant on the TC gasket but I found it nearly impossible to line up without some RTV. I think the gaskets they were using originally when the service manual was written were different than the ones they are using today so I wouldn't worry about that.
- Put grease on inside of the new crank seal. I didn't do this at first and the lip didn't go in right. Luckily I had another one from my second TC gasket set.
- Here are a few torque specs that might help some
Oil pan - 105 in. lbs.
Timing Cover - Small bolts 20 ft. lbs. Big bolts 40 ft. lbs.
Tensioner - 30 ft. lbs
Pulley - 45 ft. lbs
Water Pump - 105 in. lbs.
Harmonic Balancer - 40 ft lbs.
A few tips I have
Pulley - 45 ft. lbs
I'm close to deciding to replace the chain. But if a little chain rattle between 700 & 800 RPM is inevitable, that would put it a lot lower on my priority list.
So my question is: Did this rattle go away after the chain replacement, and did you have this rattle in the RPM band I'm referring too early on before it became worse?
Mine has had mild timing chain rattle between 700-800 rpm since day 1 (almost 130K now). It's quiet at other RPM's, so this is probably an RPM range where the chain slack gets unstable for some reason. Usually it's most noticeable on a warm start as the high idle speed is decreasing. From listening with the belt off I'm 98% sure it's the timing chain. Recently listened to a couple other 3.8 Jeeps and hear similar.
What sucks is the only way you can really tell the condition of the chain & gear set is to remove the oil pan at a minimum. Better is to pull the front cover, and at that point regardless you might as well swap out the chain & gears. BS design, combined with crap components.
Yes, after 5k miles since the replacement it's noise free. The bigger concern with these cheezy chain & gear sets is the sloughed off metal that you'll find inside the engine. The inside of my JK's timing cover was coated with it, like a grey film, as was the lifter area when I removed the intake manifolds to deal with the leaking lower intake seal. Filter will get it except during cold startup bypass which is when bearing, etc. damage is going to occur. The amount of slack I found on mine was what I would call extreme for the low miles (60k+) when I discovered it.
Finished changing out the chain, and just in time for a 2K mile trip with some Jeep friends. Here's a few thoughts before I forget...
I figured out a way to test the slack in the timing chain before disassembly, here's a link to the write-up. The cam sensor gap was set by simply retracting the sensor approximately .03 from where it touched the cam sprocket. Turned out that the chain in mine wasn't outside the limits, but the specs are pretty loose. It's silent now, all of the time. Idle is smoother, low RPM torque seems a bit better too.
The OEM chain only flexes one way, around the sprockets -- It doesn't flex backwards, the links bind to prevent that. The Cloyes replacement chain flexes both ways. Don't know what advantages there might be in either design.
To make it easier to line up the flats on the oil pump, the pump was filled with the thick Lucas oil and positioned with the flats vertical to match the crank. The Lucas makes the pump stay in place, and it should self-prime faster as well.
Used Permatex Hi Tack on the timing cover side of the gasket only. This holds the gasket in place on the cover, the other side being bare so it slides easily on the engine block for lining up the bolt holes.
This is what I do on any initial engine start when the oil system has been apart -- Generically it's remove fuel, spark, pull plugs, and crank with starter. For the 3.8L JK, remove the fuse for the fuel pump, the spark plugs, and electrical connector on the coil pack. After adding engine oil, fill the oil filter half way and install it. Crank the engine with the starter to prime the oil pump, and pressurize the whole oil system. Probably best to do this for several 30 second runs even if an oil pressure gauge is showing normal pressure to bleed out the air.
The special tools (mentioned earlier in this thread), or an equivalent, are absolutely necessary.
Reinstall:
- Install crank shaft sprocket
- I gradually heated the sprocket in oven for 20 min
- Quickly put the sprocket and it slid on without any issues, except for a hair width or two.
- So I made a little tool to push it on the rest of the way
- put a 10m - 1.5 treaded rod into crank and using the old sprocket and some washers and nut, it went the last few hairs very easily
- Install Gear and chain
- Making sure that the timing marks on gear, sprocket and chain all still line up.
Full Size
Full Size
Full Size
Full Size
Full Size - Put the timing cover gasket in place on the block, and secure by using a little RTV in 4 corners
- Install the timing cover, be sure that the oil pump lines up with the crank spindle (it will go on easier that way) do not use force
- Finger tighten the 13 cover bolts
- Finger tighten 2 AC mount bolts
- Torque everything to spec
- Install the new crank shaft oil seal
- I used the same tool as mentioned above with a different sized socket to push it into place.
- Hook up the hoses and sensors that were removed in step 13
- Install the 2 AC bolts
- Install water pump with new gasket
- Install alternator
- Install power steering pump
- Install belt tensioner
- Install Idler
- Install Oil filter
- I fill the oil filter all the way up with oil, and used a rag catch some overspill as I was screwing it on
- Install Oil pick up line
- Install oil pan
- install the new gasket
- install the ?x 10mm bolts, finger tight, then torque them from he center out
- Install dust shield
- Fill coolant
- Make sure drain bolt on radiator is closed and that all hoses are hooked up
- Fill radiator
- To help get rid of air pockets, I gently squeezed the lower radiator hose to get the fluid moving
- Fill oil
- make sure oil filter is screwed on, oil pan bolts are torqued and oil drain bolt is torqued
- fill engine with oil
- Install harmonic balancer pulley
- I used the same tool as mentioned in step 1 and 5
- Install serpentine belt
- Install air box, tube, hose, sensor
- Hook up battery
- Start Jeep.
- Crank the heat
- Keep an eye on oil light
- My Oil light went off right away and my heat was working within a minute.
Ways to prime the pump include temporarily overfilling the oil pan and/or cranking with the oil filter removed with lots of rags to catch the oil. There is a fuse to pull to prevent an engine start while cranking.
