JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   JK Write-Ups (https://www.jk-forum.com/forums/jk-write-ups-39/)
-   -   Under-Floor Storage (https://www.jk-forum.com/forums/jk-write-ups-39/under-floor-storage-178549/)
ronjenx May 18, 2011 01:03 PM
Under-Floor Storage
Go here to see this thread with pictures: http://web.archive.org/web/201604071...torage-178549/
I have seen this done before, but with a wood frame.
I wanted to keep the weight to a minimum, so I used steel studs; much more fun to work with.
Most things I always carry will fit under the cover. Larger items will fit if placed in the original depression in the floor. This arrangement keeps things out of sight. Looking in through the window, the back appears empty.
I still have to bolt it down, (will use rivnuts in the tub floor), and install a lock.
I'll show the finished product first, then some construction pics.
http://i776.photobucket.com/albums/y...rInstalled.jpg
http://i776.photobucket.com/albums/y...oorStorage.jpg
http://i776.photobucket.com/albums/y...orHalfFlat.jpg
Sliding the front seats all the way forward will allow the two headrests to go flat, too. Plenty of room to lay out a sleeping bag, or an inflatable mattress.
http://i776.photobucket.com/albums/y...orFullFlat.jpg
The dimensions of the frame allow it to sit flat on the floor, between the raised portion at the fender well bases. This leaves some room along the sides for small items.
http://i776.photobucket.com/albums/y...nx/05Frame.jpg
http://i776.photobucket.com/albums/y...FrameJoint.jpg
http://i776.photobucket.com/albums/y...erAttached.jpg
http://i776.photobucket.com/albums/y...yForCarpet.jpg
The two floor extensions, seen here folded back onto main box, are hinged to the top cover.
http://i776.photobucket.com/albums/yy41/ronjenx/09.jpg
http://i776.photobucket.com/albums/y...njenx/10-1.jpg
http://i776.photobucket.com/albums/yy41/ronjenx/11.jpg
http://i776.photobucket.com/albums/yy41/ronjenx/12.jpg
I installed a riv-nut in each side, at the tailgate end of the frame. You'll see where in another picture.
http://i776.photobucket.com/albums/y...tInstalled.jpg
A spacer at each bolt location makes up for the carpet thickness.
http://i776.photobucket.com/albums/y...eForCarpet.jpg
All four bolts installed; two pictured here. The bolts and riv-nuts on the front end of the frame, close to the rear seats, were already there for the original tie downs. The riv-nuts I installed are under the sides of the frame, close to the tailgate.
http://i776.photobucket.com/albums/y...BoltedDown.jpg
This view shows one extension, and how it rests on the extra frame member, taking the load off the hinges. You can see some useable storage space in the gap between the seat and floor.
http://i776.photobucket.com/albums/y...rExtension.jpg
This picture shows how the headrest will fold flat when the front seat is moved forward, giving plenty of room to lay out an air mattress.
http://i776.photobucket.com/albums/y...FoldedDown.jpg
The jack and tools are accessible without having to open the storage box; handy if you get a flat when the cargo floor is loaded.
http://i776.photobucket.com/albums/y...ompartment.jpg
This picture shows the jack compartment covered.
http://i776.photobucket.com/albums/y...entCovered.jpg
The last task related to this project is to figure out a nice locking system for it.
Finished the lock for the under-floor storage.
I found the lock at a local lock shop. No part number or description. It was just in a sealed plastic bag with some hardware; $12.
http://i776.photobucket.com/albums/y...jenx/Lock1.jpg
http://i776.photobucket.com/albums/y...jenx/Lock2.jpg
http://i776.photobucket.com/albums/y...jenx/Lock3.jpg
http://i776.photobucket.com/albums/y...jenx/Lock4.jpg
http://i776.photobucket.com/albums/y...jenx/Lock5.jpg
http://i776.photobucket.com/albums/y...jenx/Lock6.jpg
http://i776.photobucket.com/albums/y...jenx/Lock7.jpg
bkw May 18, 2011 01:55 PM
That looks great! Have you considered picking the woods tub enlargement kit? That + this would provide some serious storage!
ronjenx May 18, 2011 02:01 PM
I had considered it, but decided cutting a big hole in the floor, and welding in the box , is not something I wanted to do.
Starcat May 18, 2011 02:49 PM
I like the extensions to allow for the seats to lie flat. You do realize that everyone is going to want you to make this for them. :thumbsup:
BadPunkin May 18, 2011 07:03 PM
That's awesome. I have been thinking of making something like that but you nailed it. Very nice work.
How do the extensions attach to the box? It looks like the lid and the extensions are on the same hinge.
ronjenx May 18, 2011 07:18 PM
The lid is hinged to the frame. The extensions are hinged to the lid.
Looking at the last picture, the narrow extension, you can see the two little hinges for the extension to the lid, and between them, the larger hinge for the lid to the frame.
BadPunkin May 18, 2011 07:25 PM
Got it. Great job.
speed2005 May 18, 2011 07:41 PM
:thumbsup::thumbsup::thumbsup:
JeeP_MarK May 19, 2011 07:28 AM
6 Attachment(s)
Great work I made something like yours last month to keep my dog off my work gear , I like the way you flip out extension , I wonder if I can incorporate it into my design
ronjenx May 19, 2011 08:05 AM
Nice! It looks like you need more depth than I do.
I see you can lock yours. I still have to decide how I'm going to do that on mine.
© 2026 MH Sub I, LLC dba Internet Brands
