Walmart Platinum Burner Rock Lights Installation Write-Up & Review
#41
Originally Posted by DJSJK50
Fantasitic. Is there a write up or something for me wireing this up? wire for dummies, kind of thing. I think I understand what your saying. Just got to go get the parts.
#42
#43
Did that, the only two I found were from 5/2010 and they did not give instructions on how to wire. I will keep searching.
#44
Red #12 from battery to inline fuse.
Red #12 from inline fuse to relay.
( 2 ) Red #14 & ( 2 ) black #14 from relay to lights. ( One red and one black to each light )
Blacks go to ground.
Use wire loom to protect the conductors.
Oh, ( 1 ) #14 black ground to relay.
Run the wires for the switch like previously described.
Have fun on the install. You know where to find me if you need any more info!
#46
Originally Posted by BigRedJK
Hmmm maybe the thread I saw wasn't in the writeups section. I recall reading about someone wiring up rock lights with pretty detailed pics and instructions on splicing the groups of lights together. It may have been a different thread regarding splicing into the backup rear lights. Sorry if I sent you on a wild goose chase.
#47
No problem, it's all good. I did find information about the switch searching for the thread.
You might be talking about this one... https://www.jk-forum.com/forums/show...p-lamp-install
I found it just a few seconds ago. In this one, he gives the instructions on how to use the KC harness. For this mod, at least from my understanding, we will need to do all the wiring.
Sorry if I took this off in a different direction. I am going to do both and decided to have two switches, since they will be for different purposes.
#49
if you do that, you need to make sure that each pair is attached to it's own switch or, you want them all to be on the same switch, you need to use a relay and the proper gauge wiring. we did that on moby dick and it works great - will have to do that to nemo sometime too
#50
Originally Posted by nikbass
relays and larger wire between the relay and the switch was the plan. Not sure what gauge I'd need but I'm good about over-killing with wire.
330/12volts = 27.5 amps
12V/30A relay & 12 gauge wire should do the trick.
