LED interior lights
I ordered these Auxito LED bulbs to replace the interior lights in my wrangler, and every bulb is still going bright and strong including interior map, dome and reading lamps and a few others. After replacing the bulb, I still had a handful left over to use if one burns out. And because you can choose the color temp you want, I got rid of all those dingey yellow colored bulbs and now have bright clean white light. When you hold these bulbs in your hand and look closely at them, you can see and feel that they have a heaviness to them, they are not thin, flimsy or cheaply produced as you might expect a lower priced item to be, they are housed in thicker heavy plastic and feel solid.
https://www.auxito.com/collections/2...-jeep-wrangler https://cimg5.ibsrv.net/gimg/www.jk-...320541b71d.png |
| All times are GMT -8. The time now is 10:13 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
