[HOUSTON] Mod parties?
http://project-jk.com/jeep-jk-write-ups/163
Yes i gottcha covered
Sent using tapatalk
Sent using tapatalk
Sent using tapatalk
Anyone done the marker light mod yet?
quick question. Im wanting to do the Grill Mod and was wondering if you had some tin snips or some sort of wire cutters? Asking because if you don't Ill just go out and buy me some.
if your going through the gromet in the gate that houses the wire for the brake light you don't need to cut your coax.
you can pop out the grommet and cut a slit from the outside of the circle to the inside. slide your cable in, then pop th grommet back in place. it seals back up, you can hardly see the slit when it's back in place.
Thats the kicker!
Why go through the strap just zip tie the cable to the strap? I did mine this way and can hardly tell the cable is there. Then do what Rescue1 said.
