2013 Commando Green JK - 37s - Currie D44 - RCVs - Ox Lockers
Never thought I'd do this, but I need the money and a cheaper Jeep. More pics and contact info on Craigslist: https://akroncanton.craigslist.org/c...614645743.html
Even more pics on my IG: @keeponjeepinon One owner 2013 Jeep Wrangler (JK) Sport S, lived most of its life in Beaufort, South Carolina until I moved to Akron, Ohio about a year ago. I have done a ton of work to it and am only selling because of school. It has 49,xxx miles on it and has never had any major mechanical issues, and has always been maintained well. That being said, it is a Jeep, and I have used it as such, so it has some battle scars. New battery as of November and just had the airbag recall done. Commando Green paint - Only made in 2013 Drivetrain: Currie Enterprises RockJock Dana 44 front axle - 3"x0.375" wall tubes Front/Rear Ox Lockers (air actuated) with 4.88 gearing RCV front axle shafts Metalcloak 2.5" Game Changer ARB Edition short-arm lift Fusion 4x4 1-ton tie rod Synergy 1-ton drag link Adam's 1350 front drive shaft Off Road Only Sway-Loc swaybar - Dual rate disconnecting swaybar, air activated version Cooper STT Pro 37x12.5x17 tires on 17x9.5 Mickey Thompson Classic Baja Locks Engine: Volant cold air intake, with a Powercore 100k mile filter Bullydog GT for Jeep tuner Magnaflow Off Road Pro exhaust (dumps before the axle) Centerforce Dual Friction clutch Exterior: Metalcloak front and rear bumpers Metalcloak front fenders and inner fenders Metalcloak rear corner armor OEM Rubicon rock rails ORO Hop Stopper - Gets rid of the JK hood flutter Tire carrier jerry can mount. Green Spiderwebshade shade top, fits under the soft top. Interior: Sport S package (Bluetooth, Uconnect, Sirius XM, Alpine sound system, steering wheel controls, Leather wrapped wheel/shifter) ARB Twin air compressor (150psi, 6.16cfm) and a 5 gallon tank Tuffy security Enclosure - Creates a trunk in the back, I also added a Hi-Lift and shovel mount as well as the tank and compressor are mounted to it. Cobra 19 CB - Currently not working, I think the radio itself is dead (they only cost $39) Carpets have been removed, the back has been bedlined. Electrical: Switch Pros 8100 panel - Solid state switch panel with 8 switches KC Daylighters retrofitted with LED inserts Trucklite LED Headlights KC Cyclone rock lights - 8 green LED lights spread across the bottom of the Jeep 2 Yellow Cyclones are also wired as signals in the wheel wells Inspired Engineering flood lights- wired to fog harness, no CAN-bus flickering Rigid Industries DOT approved fog lights Superwinch TS9500 winch Jeep has no incandescent bulbs left. Everything is LED. I have put a ton of work into this Jeep and well over $25,000 in aftermarket parts. It pains me to sell it, but I need something cheaper to own and daily while I'm in school. $25000 OBO |
