Sunnysideup |
03-08-2019 05:16 PM |
mounting a PSC PUMP AND RES. on a 07 JK
I made this video after mounting everything, this video is just pointing out how to mount the pump with the requirements PSC has on the elevation of the res and its position. This will only work on 07-10 JK's. I mounted a PSC HD BIG BORE Box last year, and with my current pump going out I decided to use the PSC pump other than the stock pump. The steering box they sell has a much larger sector shaft and is capable of running hydro steering. The PSC pump puts out more volume (twice as much they say) than the stock pump. I'm running 37's and decided that I didn't need hydro at this time, if the box worked good with the stock pump, I would just put their pump on when I needed another pump. A year and a half later- every morning for about 6 months the stock pump has sounded more and more like it was grinding coffee... so I replaced it with the PSC kit from Northridge. It's been on the jeep for a couple of weeks now, and the systems turns and works flawlessly and no leaks... so I feel good about the idea of just upgrading the pump and the box with my Jeep. The video I made fills in the gaps for JK owners in my year range, there is not much online about where to mount things etc... I started getting requests from people to show them how I mounted it... so I just made a vid! If you are reading this Friday night... you might have an hour or so until it finishes uploading... I'm putting it on my youtube channel. Here is the link!
