JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Member Video Creations (https://www.jk-forum.com/forums/member-video-creations-186/)
-   -   What method do you use to deflate your tires? (https://www.jk-forum.com/forums/member-video-creations-186/what-method-do-you-use-deflate-your-tires-339486/)
TrailRecon 01-05-2017 10:20 AM
https://www.youtube.com/watch?v=nSlROYeRUkA
2MchFun 01-09-2017 03:06 PM
I use Staun deflators. They work like a champ!
jedg 01-09-2017 10:10 PM
Simple and cheap. I put one on each tire and by the time I get to the first one, it's aired down to about where I need it. When I'm done with the first, I move to the second and it's about done... and so on...
https://teraflex.com/shop_items/528f...d962f416e72f77
larry0071 01-10-2017 02:28 AM
Same here.
ReadyToMount 01-10-2017 01:50 PM
I like the ARB/Currie EZ Tire Deflators myself.
cabmak4life78 06-25-2017 11:29 AM
Staun are expensive but you can't beat the convenience of "set it and forget it". I never have to worry about letting out too much air.
63expert 06-25-2017 04:11 PM
1 Attachment(s)
Attachment 672793
jchappies 06-26-2017 06:19 AM
1 Attachment(s)
I've used the set-it forget it deflators and for the most part they work but they do fail too and aren't very accurate tire to tire. The ARB style where you pull the valve core works really well and is fast. But with all those that I have used I ended up building my own 4 tire inflation\deflation setup. I hook up all 4 tires and can have them deflated in 4min (30lbs to 15lbs). I can also inflate my 4 37's in 2.30 min with my shop compressor or CO2 or my OBA takes about 5min(that's all 4 tires)
Attachment 672801
caryt 06-26-2017 06:38 AM
I've tried just about all..new rims drill and use RIMROCK RAD air valves, already have 2 valve stems or don't want to drill use Jantz J-Flaters
Both the fastest and easiest I have used.
karls10jk 06-26-2017 06:43 AM
Where's the supply list on the multi tire inflate/ deflate? Are you using 1/2" air hose to get those tires filled in 2.5 mins?? I've got a large compressor but I don't see it filling 4 tires that quickly without a larger supply hose.
