OK bs
Old Feb 4, 2011 | 07:24 AM
  #1231
interceptor_1972's Avatar
Originally Posted by jfreeddo
I guess for personalized plates that "ball cock shank washer" would be too long??
Yep it would be - but here are some alternatives
BALCOCK... BALLCOK... COKSHNK... SHNKWSH... COKSANK
Old Feb 4, 2011 | 07:25 AM
  #1232
Originally Posted by TORN
I would second that.
I third it . Hey Jeff, long time no see - how're you doing?
Old Feb 4, 2011 | 07:30 AM
  #1233
...That will result in a consequential decrease in force to propel your Jeep. You can offset this by gearing, but then you've just increased the forces working on your drivetrain, while making some of the drivetrain components even smaller and weaker. So, size matters, too...
...In fact, ORE just posted up a FB photo the other day of just such a configuration where the owner managed to twist the splines on a CHROMOLLY shaft!!
Agreed .
Originally Posted by PainKiller
...I had about 15-20ft reeled out at different times...
And that can also be a key element - electric winches have the max torque and pull capacity on the first layer of spooling; thereafter, with every additional layer, the pull capacity lowers and the winch has to work harder to pull the same load, leading it to overheat faster. When distance is limited, having a snatch block will help by allowing you to spool out more of the wire.
Old Feb 4, 2011 | 02:31 PM
  #1234
TORN's Avatar
I have been busy working, Hi Interceptor , Mark D and everyone else.
Old Feb 4, 2011 | 03:59 PM
  #1235
Orange crush's Avatar
Veteran: Navy
Well had a long trip to OKC today. Left wagoner at 11:30 and pulled into the city about 4:30 with a couple of bathroom breaks and lunch.
Thought it would be easier to go 69 to I-40 and across. It was just as bad as the other roads.
Be here till Monday and then headed back
Old Feb 4, 2011 | 04:12 PM
  #1236
u-joint's Avatar
... and everyone else.
Hi
  #1237
u-joint's Avatar
How were the roads on the way to OKC? I imagine they'd be pretty bad still.
Old Feb 4, 2011 | 04:29 PM
  #1238
Veteran: Navy
Yes. I-40 was horrible till you get west of Choctaw road. I was in 4 high till there. For the most part it was one lane with the occasional passing area. Just have to watch out for the big trucks.
Old Feb 4, 2011 | 05:05 PM
  #1239
PainKiller's Avatar
Jason.....when I left your house this afternoon there were 3 cars in the ditch and one hit the ditch trying to get around them out in front of your neighborhood. those are deep ditches. i was out there for 30 minutes trying to help some girl that lived in your addition that went to get medicine for her baby. you should go out there and direct traffic for a few days. winch did really well this time.
Old Feb 4, 2011 | 05:21 PM
  #1240
u-joint's Avatar
Hey, thanks again for letting me borrow that shovel. We were able to clear the driveway enough to get my wife's car out.
