Sponsored by:
Sponsored by:
1/2 inch spacers question
Old 08-19-2017, 04:59 AM
Pete1971's Avatar
Default 1/2 inch spacers question
hey guy's , if I add 1/2 inch spacers to my 2.5 lift am I gonna have to change anything else ? just want a bit more height, it's a DD I do have aftermarket bumpers the front is about 50 pounds ( no winch) rear is about 80 pounds. no offroading..... thanks in advance
Old 08-19-2017, 10:41 AM
nthinuf's Avatar
2.5" coil lift? No problem, lots of people add spacers on top. (spacer lift? Many will recommend not stacking spacers, but some do it without issue)
The caster will be a bit lower, causing 'slightly' flightier steering. Both axles will be a bit more offset to one side. The driveshaft joints will run at slightly steeper angles. etc. Then again, you are just regaining the height lost to the bumpers, so you shouldn't notice anything at all.
Quick Reply: 1/2 inch spacers question
