2.5 rough country on jku, minimal problems
#21
Ended up going with the aev correction brackets since quadratec said the rancho kit wasnt in stock for 3 weeks. The aev brackets fit really nice and it drives a whole lot better. At the same time I did all 4 new control arms. Seems to have fixed all of that pretty well.
Now, the shocks suck. Way too soft for this jeep, they need to go. I have kings on my truck but would rather not go that route. With 9000s I'll never feel the need to adjust n crawl under to adjust but are those or would the 5100s be better..?? I know just asking an opinion, the springs are pretty soft.
#22
The Bilstein 5100s are a good shock, but will be very stiff.....the whole other end of the spectrum. That may or may not bother you. The Fox are very similar IMO and cost a few bucks more. I have Fox, and have had several buddies run the 5100s. They work for us, but just be aware they are stiff.
#24
I thought that 5100's were stiff as well. But as with most everything else, it's personal opinion and preference. The OP of this thread had the opposite viewpoint, and thinks they give a great ride.
https://www.jk-forum.com/forums/modi...lcloak-349536/
If you want other options, I went to OME Long Travel shocks after the 5100's. Softer than the bilsteins's, but not a super-soft cushy ride. They are somewhere in the middle, and they had better travel numbers than the 9000's. And MetalCloaks new RockSport shocks have similar specs to the OME's.
#25
Ok thanks for the options. I'm not sure what shocks to buy now..lol. The rc springs seem real soft and ride ok, the shocks dont soak anything up tho. Maybe the 9000 would be ok since they can be adjusted. How well does that work tho..?
#26
I have no experience with them, but previous posts have indicated that some folks have had the knobs corrode and stop working, or break off. That may depend on location/environment - harsh winters and road salt? Worth a little research.
Rancho is fairly active on the forum, so it wouldn't hurt to send them a message to get their take on it.
Rancho (03-18-2019)
#27
Knobs are easy to replace.
#28
The RS7000MT is a monotube style shock, so a firmer ride.
The RS5000X is a great all around shock, soft in general, but the way the valve shim stack is designed is that it "firms" up when the road gets tough.
And as has been mentioned the RS9000XL is adjustable for the ride you want
Matt
Matt
#30
And we have a TON of geo brackets ready to go too!!!
