2007 jku to a 2012 jk
Old Jan 18, 2012 | 12:46 PM
ChopN's Avatar
Default 2007 jku to a 2012 jk
Im considering trading in my 2007 Sahara JKU manual tranny for a 2012 Sport two door manual. Id like to trade it in stock and move my TF 2.5, wheels/tires, and bumper over to the 2012. Will there be any issues with the lift? Would I need to get a new driveshaft?
I do plan on regearing btw.
Old Jan 18, 2012 | 01:11 PM
wasntborn2follow's Avatar
I have been running a 2.5 unlimited kit on my 2 door. I have 1" spacers also so i figure i have around 4 inches of lift. I know im going to have to replace my rear driveshaft sooner or later. But you will be fine for sure. On the 2012 you might have to do the exhaust flanges though.
Old Jan 18, 2012 | 02:35 PM
kwolf's Avatar
You'll only have ds problems with lifts 3" and up (angle) and/or if you run shocks that are 27.5", such as Bilstein 5100's, which at full droop (swaybar's disco'd) will cause your stock ds and exhaust pipe to hit each other.
Sounds to me like you're good to go.
If you're running 33's on a '12 with 3.73 gears, you shouldn't need to regear. Bigger tires or higher gears (3.21's), well then, yeah...
Old Jan 18, 2012 | 02:43 PM
ChopN's Avatar
Thanks guys. Looks like the only issue is the driveline hitting the exhaust. Now i just gotta decide if i really want it.
Old Jan 18, 2012 | 04:11 PM
ChopN's Avatar
The dealer tells me my jku coils will not transfer over to to a 2012. Is this true?
Old Jan 18, 2012 | 05:25 PM
not true. they will work.
Old Jan 18, 2012 | 05:29 PM
kylepage's Avatar
they'll work just fine..dealer just wants you to leave the lift on.
Old Jan 18, 2012 | 06:31 PM
ChopN's Avatar
I left it on. Im gonna take a different route this time.
Old Jan 19, 2012 | 11:55 PM
FlameRedJK's Avatar
Im about to lift my 2012 JKU...I originally bought the TF exhaust spacers which you WILL need with a 2.5" lift(thanks Jeep) but, I decided to go with the AFE Y-Pipe instead to just do it right the first time with my 3.5" lift.
Either way, if lifting a 2012, you will most definitely have exhaust issues....Trust me...
