2010 Jeep Wrangler cranks but won’t start.
For the past couple months my 2010 Jeep Wrangler won’t start, it would crank on and off when ever I turn the key, it’s not the battery I’ve tested it and even bought a new one. Does anyone know what this could be or any ideas on how to fix it?
Perhaps one of your grounds is loose?
Take a read through these. I didn't look closely at them, but they may be related. https://www.jk-forum.com/forums/jk-w...e-help-345249/ https://www.jk-forum.com/forums/stoc...art-up-318623/ https://www.jk-forum.com/forums/stoc...issues-345252/ https://www.jk-forum.com/forums/soca...-start-274604/ |
An engine needs 3 things to work (as least used to), i would start by making shur you are getting spark (check the plugs), next would be fuel. can typically do both at the same time as you crank it will spray and you can smell it on the plugs. it is very rare that you arnt getting air but ya. if the motor is getting all those then its something with the computer telling it not to run. and good luck on that part :crazyeyes: i know this sounds stupid and simple but it is the easyest way i have learned to lean me towards what i need to focus on more.
Originally Posted by DEJK2012
(Post 4339364)
