2010 Rubi ring gears
Hello all, a fellow jeep owner is selling used 4.56 gears, he says are dana 44. I pulled the ring gears outta the box, one is bigger. Shouldn't Rubicon dana 44's be the same size front and rear?
Negative, the rear should be slightly bigger. Front ring gear diameter should be 8.5" if I recall correctly, and the rear is like .25" to .30"(?) larger.
Dana 30 ring gear is like 7 and 1/8" diameter (for those of you on this forum who think 37's are acceptable on a D30 :omg: ) |
For the tiny bit of savings you might see in used gears, you are much better off going with brand new. This wouldn't be an advisable place to skimp.
https://cimg2.ibsrv.net/gimg/www.jk-...ef59c327f2.jpg
Like this? So these are Rubicon 4.56? |
Thanks all, I'll go with new.
Originally Posted by Skoden10
(Post 4317111)
