2011 JKU Rubicon Locker Bypass
Hi guys,
I'm sure this question has been asked, and I'm sure there are quite detailed threads on how to do this. Can someone please post the link for the Rubicon locker bypass switch so I can run my front and rear lockers in 4H?
Thanks!
Thanks!
Originally Posted by DownhomeMoto
I know with the SC programer you can. But I wounder if one couldn't just rewire them for 12v and their own switches. That way you can have them when ever you wish.
Yea I read that too... Something about grounding the purple wire on the solenoid. Its a really detailed write up but not sure were it is, i read it early December if that helps.
Thanks guys...I did try a search but what came back was not really comprehensive. I wish someone would do a write up on this. Any of the programmers can do this, but you have to have the programmer plugged in and hold the button down to make it work. They don't tell you that when you read about the programmer. Not really useful like that. I want to have two 12v switches, one for the front and one for the rear that I can use in 4H or 4L. I'm sure it can be done, but I'm the kind of guy that needs those detailed step-by-step instructions.
There is a write-up with good detail.
The mod is simply running a wire from the locker relay ground through a switch in the cab.
It will lock any time you throw the switch, but the light will keep blinking. Normal operation is preserved.
Hmmm...gonna have to try this next time. Was gonna get a SC for this feature but didnt want to spend 300 plus bucks just for that feature
