2012+ Longest front shock with stock driveshaft
I'm trying to max down travel on my 2014 front suspension with the stock drive shaft, what is the longest shock I can run in the front without the stock drive shaft hitting the exhaust? And by how much will that increase with a exhaust spacer?
Thx.
Thx.
Hey Dirtnan, thanks for the reply. I found two shocks with aprox 10" of travel, one is a rock krawler 2.0 and the other is a bilstein 5100. Now, the bilstein with 9.63" inches of travel has an extended length of 24.63" while the rock krawler with 10" inches of travel has an extended length of 27". That's 2.37" more inches of potential drop. So I don't think travel is the answer I'm looking for, I'm more interested in extended length. Thanks again.
Disconnect your sway bar links and shocks and jack the jeep up until the driveshaft hits the exhaust then measure between the upper and lower shock mount. This will give you the maximum length of shock you can run. Then leave the links and shocks disconnected and jack up one wheel until the tire makes contact with the fender. Measure the mounts again for your minimum compressed length.
Once you get these lengths you can search the manufactures websits to find the longest travel with shortest body that will fit on your jeeps set up.
