2012 Regear!
I just posted what my local dealer is running into, and the programming is totally different with the penastar motor and new transmission. I told the guys at the dealer to try the procal, looking forward to hearing back from them, but right now they have a mess, and will probabbly have to put the stock gears back in, will keep you guys posted, pretty big deal
Warning: Changing gears on a 2012 JK will cause it to go into limp mode.
2012 JK Wranglers now include the A580 transmission. With this new trans comes a new trans controller, and unfortunately this controller is programmed to put the vehicle into limp mode if it senses a change in gear ratio. Even a Jeep dealer cannot override this.
AEV has a fix for this and we are currently working on integrating it into our ProCal Module. In the meantime, we recommend that you hold off on changing the gears in any 2012s. We expect ProCals with the updated code to be available by the end of September.
I was going to post the same. AEV stated this earlier in the week the current ProCals ant help with the limp mode experienced when regearing a 2012.
My guess is the old ProCals will be eligible to be updated to the new coding once available. AEV has been great with regard to customer service so I would be surprised if someone was left high and dry.
Someone else asked this on another board but I didn't see an answer, the Procal will fix this but what happens when you need to return everything to stock mode for a trip to the dealer? Will you be stuck in limp mode then?
I was at the dealer when I pick up my 2012. There was a guy who had a 2012 regeared at the dealer with 5.13. I told him about the problem, He said They had no problem with this limp mode.
