JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   2012 vacuum pump bracket removal? (https://www.jk-forum.com/forums/modified-jk-tech-2/2012-vacuum-pump-bracket-removal-218029/)
eslack32 Feb 11, 2012 06:27 PM
Has anybody removed the bracket from the frame all together? I've read all about relocating the pump for aftermarket bumpers, but I need the bracket gone and wondering how much of a PITA it is. The reason I need it gone is because I wanted reuse the MBRP light bar I took of my 2010. If its not worth fighting with the bracket.
mattgt5 Feb 11, 2012 07:20 PM
I had to cut mine off to get a winch in. It took all of about 5 seconds with a reciprocating saw and a metal cutting blade from Lowes. I was all worried about it too, but it cut like butter
eslack32 Feb 12, 2012 06:41 AM
Thanks! Just the answer I was hoping to get. :beer:
AzDesertRacer Feb 12, 2012 07:08 AM
A plazma cutter made quick work of my pump bracket. I flipped the swaybar disconect and removed the lower crossbar as well.
What is the vacumm pump for anyway?
SG
ranjr Feb 12, 2012 10:36 AM
Originally Posted by AzDesertRacer
.What is the vacumm pump for anyway?
The brakes!
autox-racer Mar 28, 2012 09:53 AM
I put my old mopar bumper on 2012 and cut off bracket, removed and plugged vacuum pump lines. I have not noticed any ill effect. My guess is it is used for start up low vac conditions. My wife's sky has very poor vacuum assist when first started. Almost scary on a hill. Jeep does not seem near as bad.
bowerss2 Mar 28, 2012 10:10 AM
Originally Posted by ranjr (Post 2845240)
The brakes!
yup. Now why Chrysler decided to go with a vacuum pump and vacuum assist breaks is beyond me. If they needed a vacuum pump they would have been better off tapping into the power steering and doing hydro assist breaks and eliminating the pump. But what do i know.
Grand Umpah Mar 28, 2012 04:35 PM
I had no access to such quality tools.
30 minutes with a keyhole saw with a metal cutting blade, two busted knuckles, and the bracket was gone.
silversurfer575 Mar 28, 2012 09:56 PM
I did the ORO relo bracket this evening. Took me about an hour to get it done. Real easy.
Now, ready to cut the bracket off. I don't expect any issues. Will use either a cut off wheel or saw all with a metal cutting blade.
Good luck.
© 2026 MH Sub I, LLC dba Internet Brands
