2wd to 4wd conversion help!
About to start this project on my 07 JKU.
Making a parts list and just trying to double check everything! 2wd to 4wd conversion 1. Front axle with 4.10 gears 2. Front & Rear driveshafts 3. Transfer case 4. 4wd shorter tailshaft 5. Shorter adapter for transmission to T-Case 6. Cross Member tranny mount 7. 4wd shifter 8. 4wd shifter cable 9. Tail housing 10. Tail housing mount 11. Input shaft 12. Tail housing cable bracket 13. Shaft clip If you've done this or know anything about it let me know if i missing anything! Thanks! |
How did u end up with a 2wd jeep?
You ll need 4.10s for the rear my guess since its 2wd it don't got them
I think it's a noble effort, but wouldn't it just be cheaper to sell your 2wd Jeep and buy a similar one in terms of year/mileage with 4wd?
Originally Posted by grizzwald
(Post 3546037)
ditto - isn't worth the trouble...sell it and get a used or new one already set up.
I know there is a thread on here about it, I'm just too lazy to find it for you.
Good luck with your project!!! |
Originally Posted by Rocky Clymer
(Post 3546064)
Originally Posted by LikeMike850
(Post 3543792)
Making a parts list and just trying to double check everything! 2wd to 4wd conversion 1. Front axle with 4.10 gears 2. Front & Rear driveshafts 3. Transfer case 4. 4wd shorter tailshaft 5. Shorter adapter for transmission to T-Case 6. Cross Member tranny mount 7. 4wd shifter 8. 4wd shifter cable 9. Tail housing 10. Tail housing mount 11. Input shaft 12. Tail housing cable bracket 13. Shaft clip If you've done this or know anything about it let me know if i missing anything! Thanks! # 4 , 9 and 10 take off your list Here is some pictures of the adapter and adapter mount http://i257.photobucket.com/albums/h...f/7bbd9151.jpg The bracket to hold the cable on the adapter http://i257.photobucket.com/albums/h...f/31fd8c6d.jpg |
Originally Posted by jk_sea
(Post 3546050)
I converted mine and my total cost after upgrades was 1800 |
