315/70r17
Old Apr 5, 2012 | 08:27 AM
Wgrin's Avatar
Default 315/70r17
Just got them on yesterday, discount tire said I need to run 40psi to keep the tire pressure light off based off volume of the new tire. Is there a way to reprogram that light/sensor so I don't have to run them so full? I can tell they are running harder in the center of the tire because the small rubber tabs on a new tire have worn on the center but the outsides of the running surface still have their tabs. Obviously running a little inflated.
Old Apr 5, 2012 | 08:51 AM
Moraespedro's Avatar
Get a tunner or a pro cal.
Old Apr 5, 2012 | 09:06 AM
IcyFridge's Avatar
It doesn't matter what size the tire is... the pressure is always the same. 35psi in a 35" is the same as 35psi in a 31" tire.
I say air it down to 30psi and you're all set. If you need to go lower, then you might need a third party tuner/reprogrammer to turn off the TPMS light.
Old Apr 5, 2012 | 09:07 AM
GunDude's Avatar
I would do the chock test and get them running even and do not worry about the light till you can get a Procal to turn off the tpms! We need pics asap!
Old Apr 5, 2012 | 09:19 AM
Wgrin's Avatar
Yeah plan on pics today. I'll try dropping a few psi today and see how it goes. If the light comes on I may have to suck it up and put more pressure cause I can't handle that light being on.
Old Apr 5, 2012 | 09:28 AM
BeachJK's Avatar
What weighs more 35 lbs of feathers or 35 lbs of rocks?
Obviously the guy that told you that never paid any attention in school.
Old Apr 5, 2012 | 09:36 AM
banx's Avatar
A 35 needs to be aired down to 28-30. Best bet is to chalk test it to find the range. At 40 you are going to wear down the inner tread pretty quick. Get a Pro Cal, it's a worthy investment and then you can shut the TPMS off and not worry about it.
Old Apr 5, 2012 | 09:53 AM
texwillys's Avatar
I agree with what's been posted. Don't forget to check the pressure in your spare!
If it's different from the other tires it can set off the TPMS.
Old Apr 5, 2012 | 10:24 AM
Sparkplug's Avatar
Yep, I run 28-30 in mine. That's where the chalk test told me to go. Those things are too expensive to wear out faster than necessary.
Old Apr 5, 2012 | 10:27 AM
toyman's Avatar
I have a Procal that I am selling. I just can't put it in the for sale section due to not having 50 posts. Send me a PM. It's only 3 months old.
