RedneckJeep |
02-25-2008 07:50 AM |
Let's get some clarification on all of this. Changing tires does NOT change gear ratios. No how, no way no where, no time. A 4.10 gear is a 4.10 gear, now and forever. Now, what changing tires DOES change is called the "effective" ratio. In other words, the FINAL drive ratio. We all know (I hope), that a larger tire takes longer to rotate one RPM at the same speed as a smaller one. So, when we put larger tires on a vehicle whose FINAL drive ratio is 4.10, we change the final (effective) drive ratio to a higher gear. Gears are confusing. The numerically higher the gear, the "lower" the gear, and the numerically lower the gear, the "higher" the gear. In other words a 4.10 is a lower gear than a 3.73.
