34x10.50 R17 Tire Options?
Debating a small lift and some new tires. Would be keeping factory rubicon wheels.
Thinking something in a 33x10.50R17 or 34x10.50R17 so I can get some height without unnecessarily adding rolling resistance or the running concerns of a wider tire.
In terms of size, I'm talking about actual size, not advertised size. I'd like a rugged AT or less rugged MT.
Thoughts on tires in this size?
You can get. 255/80/17 which is a skinny 33. Closest for 34 will be a 285/75/17. They will be about 11.5" wide.
None of these are actual size mounted under vehicle weight. If you want a tire that actually measure 34" under weight and normal PSI then you are looking at a 35, if lucky it will measure 34" under the vehicle.
how much weight. I parked next to someone the other day that had them and they visually looked shorter then mine altho a little wider for some reason. mine was new style rim his was the old style rim.
I'm running the rugged ridges wheels with them. I believe the combo weighs in around 75 pounds. The wheels are 32 pounds so the tires are about 43 pounds, I think. As for for the vehicle weight I have have a 2dr with heavy bumpers and skids. I would say I'm a good 600 plus pounds over stock.
