34x10.50 R17 Tire Options?
it is recommended that when you rotate your tires to set the torq wrench to 80ft/lbs and make sure they are all still tight. You don't go more then that as you do not want to break the red locktite. I have never had one move at 80 ft/lbs and I have had to remove them once and all were locktited in place just like they should be. I rotate every 3000 miles but would have no issues going 6000 miles between checking. Original proper install is crucial and I would never trust anyone but myself to install them but that is just me.
I think I will get some so I can run larger tires, can't afford aftermarket wheels right now but want to go with some larger tires. I've been told with the stick wheels that I shouldn't go any wider then 10 inches and see a lot of y'all running 11.5, any issues with that?
This thread covers it in much more detail: https://www.jk-forum.com/forums/jk-t...-tires-270499/
I was in that same boat. There are not so many options out there, since everybody wants them as wide as possible to make his bro truck look cool:
- 255/80R17 BFG KM2, around 33.3 inch in diameter (usually fits w/o lift/spacers)
- 275/70R18 Cooper ST/Maxx or STT, around 33.1 inch (usually fits w/o lift/spacers)
- 35x10.5R17 Interco SSR, they say 35.3 in in diameter and more like 11.6 inch wide (will obviously need lift and spacers) also this tire has some weight too (76 lbs)
