35s on 18" BS?
hi all, gotta question the rims i want only come in 17x9 & 20x9 with 4.5 bs the 18s are 5bs i would rather not run spacers . can i run a 35" tire either toyo at2 extreme or duratrac which both measure about 34" when mounted with a 5"bs. this is for a jku 2014 sahara my DD i will be getting a teraflex 2.5 coil lift. thank you:thinking:
1 Attachment(s)
You should be able to run that setup with no problem. I run 275/70R18 (33x11) with 5"bs and still have room when the tires are at full lock. If you do rub Wayalife or Project-JK has a write up on shimming your wheel stops with a washer. Simple fix.
Attachment 524649 |
| All times are GMT -8. The time now is 09:06 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
