JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   35's rubbing no lift question (https://www.jk-forum.com/forums/modified-jk-tech-2/35s-rubbing-no-lift-question-217083/)
Fiveofun Feb 4, 2012 08:16 PM
1 Attachment(s)
I searched, didn't see the question asked.
I plan on doing no lift. If I install flat fenders, will 35's rub when fully stuffed?
I ran my Rubi with the sway bar disconnected today for the first time, and was surprised how stuffed the front tire was at one point.
Attachment 274074
jkjacksonjack Feb 5, 2012 04:41 AM
1 Attachment(s)
I've done a lot of looking and what I've come up with is that if you are running the correct backspacing that the only thing you will need to do is rear bumpstops.
I'm running 315/70 17's which are suppose to be 34.4 x 12.40x17
Here's mine
Attachment 274121
echoshotz Feb 5, 2012 06:54 AM
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=274074"/>
35s, no lift, and flat fenders should get you by with a bit of articulation. But after disconnecting you will most likely rub at full stuff. You'll want to run atleast a budget boost.
Battlefrog Feb 5, 2012 06:58 AM
It can be done with correct backspacing 4-4.5" and flat fenders. You will also want to trim rear pinch seam and probably chop front bumper if still stock and remove front air dam...
Battlefrog Feb 5, 2012 07:00 AM
After seeing your pics, those rubi rails will need to be trimmed in the rear at 1.5 - 2" or your going to rub during flex..
© 2026 MH Sub I, LLC dba Internet Brands
