37" Nitto Trail Grapplers, or your Tire Brand... What is your street PSI????
What are you guys running your Street PSI at on your 37" Trail Grapplers? Or if you are running 37s in general? Curious what everybody is running. Just asked about the Trail Grapplers cause that is what i run. Thanks everybody
If you could list:
Wheel Make/Model and Size:
Tire Brand and Size:
Thanks
Ready GO.....................
If you could list:
Thanks
I run 28 psi in my 37" Ridge Grapplers. They are D rated. I ran 26 lbs in my last set of E rated Trail Grapplers. A chalk test is the best way to figure out the best pressure, as tire load ratings and vehicle weight make a big difference.
37" Nitto Trail Grapplers - 30psi on street.
Have not done the chalk test... im gonna look into this. Thanks
I have never run tire pressure this low before... is 30 and under PSI on the street what Nitto recommends with these tires? Before my current 37s the biggest tire i had run was a 35.. even then i think i was running at mid 30s. From the looks of it, and i have not done a chalk test yet, but i may have to drop down to around 26 or 27psi.
