37" Tires and PSI
#21
Proper tire inflation for oversized tires must be calculated with a formula where vehicle weight and tire max capacity are taken into consideration... I your tire man doesn't know this then either educate him or move on to another tire shop.
Doing the base calculation as your starting point then back up with a chalk test is the best method. I have found the calculation to be spot on.
formula as follows:
5000lbs GVWR vehicle is 1250lbs per corner (tire)
If load range on tire says 4080lbs @65psi the math is.
4080 (lbs) a 1250 = 2830 (reduction of weight)
2830 / 4080 = 0.6936 (% reduction in weight)
65(psi) X .6936 = 45.08 (45psi)
65 - 45 = 20psi at 1250lbs load to maintain PSI ratio in balance for sidewalls for proper temperature dissipation..
So your starting point would be 20 psi for this tire.
formula as follows:
#22
That's the stupidest thing I ever heard. These guys should know what's printed in the tire is max pressure. Also if they want to go by a "number" they should be going on the tire pressure number inside the door jam. Even so that number is recommended for stock size tires. How does a tire shop not know that tire pressure should be based on both tire size and vehicle weight
#23
