4″ LONG ARM kit information
Old Dec 26, 2007 | 08:54 AM
Grkmf3's Avatar
Default 4″ LONG ARM kit information
Ok boys,... and girls. I am thinking about doing the 4″ LONG ARM kit from Full Traction with 37's Part# FTS7340 (2 DOOR). The question is, right now i drive an 08 X. i wouldnt worry that much if it was a rubicon, but with the Dana 30 up front i get worried. what exactly would i need to make this work. Im thinking that i would need new axle's, new drive shaft, new gears. if i need all these, where would i look for them. any help would be nice.
thanks, Dino
Old Dec 26, 2007 | 09:12 AM
Grkmf3's Avatar
And would you consider an AirRock kit to go with it?
Old Dec 26, 2007 | 12:25 PM
Grkmf3's Avatar
ANYBODY, please?
Old Dec 26, 2007 | 12:33 PM
Piginajeep's Avatar
thanks, Dino
First off, the HP D30 is a strong axle. If you dont hit the skinny pedal. It'll hold up. If you have enough spare cash 4wd sells rubicon 44's for around $1,400.
5.13 gears is going to be a must to bring it back to stock performance. If not it'll be a dog.
You'lll need new driveshafts for sure, They might hold up for a little while, But I would not want to chance it, JE REEL makes three different styles to fit your needs.
Great choice on the lift, its what I plan on running when I can save the coin
Old Dec 26, 2007 | 03:15 PM
muddpuppy01's Avatar
if you are worried to much about axle breakage you could slip in some chromoly axle shaft in the front
Old Dec 27, 2007 | 06:57 AM
captsam54's Avatar
Default 4" long arm
I put a Rancho 4" long arm kit in my JK.. Didn't need anything else.. No driveshafts etc.
Old Dec 27, 2007 | 07:06 AM
Piginajeep's Avatar
First off you have a 4 door that makes a big difference in the need for driveshafts.
You can get away with alot more with a 4 door than a 2 door.
Are you running 35's? or 37's?
35's is ok with stock gears, 4:10's. But it isnt for shit on the highway. 37's i wouldnt even consider without regearing.
Old Dec 27, 2007 | 01:52 PM
Grkmf3's Avatar
does anybody have any pics of the Full Traction 4" long arm kit with 37"s?
Old Dec 27, 2007 | 02:05 PM
Piginajeep's Avatar
http://my.project-jk.com/showgallery.php?cat=938
Old Dec 27, 2007 | 02:20 PM
Northridge4x4's Avatar
Sponsoring Vendor
I think it needs to be said that these kits are not ready for shipping yet. They should be in the middle of January. Currently I believe it is installed on four jeeps getting tested.
David
